clk_mode for ethernet - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AI (https://www.kincony.com/forum/forumdisplay.php?fid=29) +--- Thread: clk_mode for ethernet (/showthread.php?tid=8830) |
clk_mode for ethernet - cvonk - 12-20-2025 When flashing with ESPHome, I get the following warnings Code: WARNING [ethernet] The 'clk_mode' option is deprecated and will be removed in ESPHome 2026.1. Please update your configuration to use 'clk' instead.Can you tell me if I should specify External clock or Internal clock. Details at https://esphome.io/components/ethernet/ Also, can you share the schematic? Thanks RE: clk_mode for ethernet - admin - 12-20-2025 before: Code: ethernet:now: Code: ethernet:RE: clk_mode for ethernet - cvonk - 12-21-2025 Thanks |
