Help with Product Slection - Printable Version
+--- Forum: Suggestions and feedback on KinCony's products (https://www.kincony.com/forum/forumdisplay.php?fid=39)
+--- Thread: Help with Product Slection (/showthread.php?tid=8832)
Help with Product Slection - phrfpeixoto - 12-21-2025
Hello!
I'm building a new apartment and need some help picking up a product from Kincony's lineup:
There are too many similar boards, with subtle differences, so it's a little confusing which to select.
Here's what I'm planning for:
- Automated lights everywhere. I think I can consider 3 light circuits in each room
- IR integration for HVAC split systems (heat pumps)
- Automated curtains (roll-on or some railing system)
- Power measurement over each power phase (no need for individual circuit measurement)
- RF 433 MHz support for future use
About the space itself:
It's a 190 sqm high-rise apartment, with 4 bedrooms (suite) + large living room (with balcony), kitchen, and mudroom
Also:
- I live in Brazil, and power here is usually a 3-phase 220v system.
- Lighting nowadays is LED-based, but all bulbs and fixtures are always AC 220V. I've never shopped for DC lighting (12 or 24V).
- Power outlets are rated for 10A @ 220V. High-power outlets (mud room, kitchen appliances) are 20A @ 220V
Other things I'd like:
- I want to use regular dry-contact wall switches: Specialty or wireless switches are a big no for me.
- I would like to use CAT5 UTP cabling for switches, if possible.
- I would like to use POE for powering as many devices as possible
- I have no interest in TUYA, and I'll use a Home Assistant setup, so the board needs to support ESP Home
Please help, I don't know what  boards to choose.
RE: Help with Product Slection - phrfpeixoto - 12-21-2025
Here's a few of the boards I've looked at, that might(?) work? Which one is the best, and how many?
- https://www.kincony.com/esp32-k-type-thermocouple-24ch-relay-module.html
- https://www.kincony.com/4g-esp32-relay-board.html
- https://www.kincony.com/16ch-esp32-poe-ethernet-relay-module-kincony-e16p.html
- https://www.kincony.com/esp32-input-module.html
RE: Help with Product Slection - admin - 12-21-2025
A32Pro is best of these boards.
you can select products by this tool: https://mq.kincony.com/qq/product/product-selector
all our products support home assistant.
RE: Help with Product Slection - phrfpeixoto - 12-23-2025
Can you please share the Relay part number for these boards?
https://www.kincony.com/esp32-16-relay-din-rail-relay-module.html
RE: Help with Product Slection - admin - 12-24-2025
A32 Pro use relay: HF-46F-G 12-HS1T 7A/250vAC 7A/30vDC
E16S use by OMRON G2R-1-E-12VDC relay
RE: Help with Product Slection - hspadacini - 06-04-2026
Bonjour Monsieur ;
Dans le cas d'un A32 pro , les entrées  optocoupleurs admettent (par groupe de borniers en 8 entrées soit 8 octets) une tensions de 220 Vac par groupement ou il faut reste en 24 Vcc ???
Cordialement.
RE: Help with Product Slection - admin - 06-04-2026
digital input ports use by DC12-24V or 0V.
