linux command line / bash scripting - Printable Version
+-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=72)
+--- Forum: TA (https://www.kincony.com/forum/forumdisplay.php?fid=76)
+--- Thread: linux command line / bash scripting (/showthread.php?tid=8899)
linux command line / bash scripting - almman - 01-11-2026
I currently use AD2USB to communicate with my Honeywell Vista alarm system. Together with ser2sock (serial to socket), in bash/Linux, I use:
if exec 3</dev/tcp/localhost/444555 ; then
  cat <&3 | while read -t12 msg ; do
        # Print last keypad/console message.
        # Example: ****DISARMED****  Ready to Arm
        echo "$msg"
        sleep 1
  done
fi
There are also functions to send commands to the alarm as if it were typed on the keypad.
How does one send/receive to/from the TA ESP32-S3 via command line/bash scripts?
Thanks
RE: linux command line / bash scripting - admin - 01-11-2026
after download KCS v3 firmware to TA esp32 module. TA support HTTP, MQTT, RS485 modbus different protocol. the protocol documents see here:
https://www.kincony.com/forum/forumdisplay.php?fid=75
RE: linux command line / bash scripting - almman - 01-11-2026
Wow! There appears to be lot's of flexibility as there are many protocols to choose from. I'm excited and will definitely buy one of these. Thank you!
