Problem with KCS flash after use ESP Home - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: "KCS" v2 firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40) +--- Thread: Problem with KCS flash after use ESP Home (/showthread.php?tid=8953) |
Problem with KCS flash after use ESP Home - tidek1507 - 01-18-2026 Hi I have A32 PRO board. I used KCS firmware. i'm a beginner with Home assistant and ESP. Today i was trying to integrate this with Home Assistant. I used .yaml file by ESPHome builder in HA, but i didnt know that this erase KCS firmware. Now when i try to flash KCS board didnt response on this. After flash in console i see: Uploading stub... Running stub... Stub running... is stub and send flash finish But board didnt work. When I flash .yaml for esp home board is connect with HA, but for now i need KCS firmware, i have to fast repair ligts control by switches, becouse my wife is mad now ;d. Can you help me? RE: Problem with KCS flash after use ESP Home - admin - 01-18-2026 i suggest you download KCS v3 firmware to A32Pro. enable mqtt auto discovery function for home assistant. so that easy integrate to home assistant. You not need to use ESPHome. if you MUST want use by ESPHome, KCS v3 firmware will be eraser. here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3-firmware-esp32-board.html RE: Problem with KCS flash after use ESP Home - tidek1507 - 01-18-2026 I want to use KCS, but i can not flash it. When i trying ESP download tool looks as below, but board didnt work. I did everything with your instruction, even with download button click. Chat gpt told me, that maybe I erased bootloader when i use esp home. Is it possible? RE: Problem with KCS flash after use ESP Home - admin - 01-18-2026 you have not checkbox. lost step-3, see the photo.
RE: Problem with KCS flash after use ESP Home - tidek1507 - 01-18-2026 Oh my... Sorry. I'm sure, that i checked it when i try first time, but later i dont. First time propably i made another mistake. Thanks!!! |
