F8 on device physical switches in ESPHome - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62) +--- Forum: F8 (https://www.kincony.com/forum/forumdisplay.php?fid=79) +--- Thread: F8 on device physical switches in ESPHome (/showthread.php?tid=9120) |
F8 on device physical switches in ESPHome - Vinceken - 03-14-2026 Hi - with esp-idf in ESPHome, how can I access the state of the physical on device switches? I can't seem to observe those on any GPIO pins. I would like to configure (in esphome) some of them to control their output relay directly, but for others for them to act as momentary switches. I can manage all the coding myself if I can work out where to observe their state... Thanks. RE: F8 on device physical switches in ESPHome - admin - 03-15-2026 the switch on the box works without any software and firmware, it's physical, it used in emergency situations, even if controller is broken. if you want use switch panel , you should connect to digital input ports with momentary switch, that will feedback relay state. |
