4x a16 modbus between - Printable Version
+--- Thread: 4x a16 modbus between (/showthread.php?tid=9301)
4x a16 modbus between - wchpikus - 05-02-2026
Hello.
Esphome, is it possible to control some output in one controler using input from other controller using modbus?
Via lan i can use post to webserver (bdw i can not find read status example using get).
Somebody has some yaml example how to do connection like this?
I like to set by software controlling light without cross switches cable between a16.
Just set some script and connect input to script what will be toggle output in remote output with read state.
Regards
RE: 4x a16 modbus between - admin - 05-02-2026
why not use by KCS firmware, send customize command by HTTP or TCP or UDP.
RE: 4x a16 modbus between - wchpikus - 05-02-2026
i will try..mayby this is sollution
RE: 4x a16 modbus between - admin - 05-03-2026
use by IFTTT, send customize protocol , it's easy.
