KC868-A8 PCB V1.4 ESP32 I/O pin define in Arduino IDE - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: KC868-A8 PCB V1.4 ESP32 I/O pin define in Arduino IDE (/showthread.php?tid=963) |
KC868-A8 PCB V1.4 ESP32 I/O pin define in Arduino IDE - admin - 10-27-2021 #define ANALOG_A1 34 updated in PCB V1.4 #define ANALOG_A2 35 updated in PCB V1.4 IIC SDA:4 IIC SCL:5 Relay_IIC_address 0x24 Relay1 = pcf8574.pinMode(P0, OUTPUT); Relay2 = pcf8574.pinMode(P1, OUTPUT); Relay3 = pcf8574.pinMode(P2, OUTPUT); Relay4 = pcf8574.pinMode(P3, OUTPUT); Relay5 = pcf8574.pinMode(P4, OUTPUT); Relay6 = pcf8574.pinMode(P5, OUTPUT); Relay7 = pcf8574.pinMode(P6, OUTPUT); Relay8 = pcf8574.pinMode(P7, OUTPUT); Input_IIC_address 0x22 Input1 = pcf8574.pinMode(P0, INPUT); Input2 = pcf8574.pinMode(P1, INPUT); Input3 = pcf8574.pinMode(P2, INPUT); Input4 = pcf8574.pinMode(P3, INPUT); Input5 = pcf8574.pinMode(P4, INPUT); Input6 = pcf8574.pinMode(P5, INPUT); Input7 = pcf8574.pinMode(P6, INPUT); Input8 = pcf8574.pinMode(P7, INPUT); DS18B20/DHT11/DHT21/LED strip -1: 14 DS18B20/DHT11/DHT21/LED strip -2: 13 DS18B20/DHT11/DHT21/LED strip -3: 32 updated in PCB V1.4 DS18B20/DHT11/DHT21/LED strip -4: 33 updated in PCB V1.4 RF433MHz wireless receiver: 15 Ethernet (LAN8720) I/O define: #define ETH_ADDR 0 #define ETH_POWER_PIN -1 #define ETH_MDC_PIN 23 #define ETH_MDIO_PIN 18 #define ETH_TYPE ETH_PHY_LAN8720 #define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT RE: KC868-A8 PCB V1.4 ESP32 I/O pin define in Arduino IDE - robbansson - 04-17-2024 same pins in V1.6 as in V1.4 ?? RE: KC868-A8 PCB V1.4 ESP32 I/O pin define in Arduino IDE - admin - 04-17-2024 yes, it's same. |
