B32M power consumption - Printable Version
+-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=60)
+--- Forum: B32M (https://www.kincony.com/forum/forumdisplay.php?fid=105)
+--- Thread: B32M power consumption (/showthread.php?tid=9945)
B32M power consumption - nogrz - 11-11-2026
Hi,
What is the maximum power consumption of the B32M controller itself, with all 32 inputs active and all 32 MOSFET outputs switched on (without external loads)?
I need this information to properly size a buffered 24V power supply.
Thank you!
RE: B32M power consumption - admin - 11-11-2026
it according to your load's current, if you use mosfet output ALL ON. suggest you use multi meter to test.
