COL - start index error
#11
this is col pc software in my pc with 1920*1080. where have problem with your window?
my monitor is set in full hd, 1920x1080. however the "kincony sbc" screen is poorly proportioned.
in red I have highlighted the side that needs to be moved to have a complete view. from the settings I have: 1230x740 and even if I change them to 1920x1080 they immediately return to the previous value. I can't get a screen like yours.
maybe you can change this setting.
i am using PC monitor, do you use tablet? or PC monitor?
use 40" monitor, recommended is 150%
my means, change the recommended to 100% for a test.
I tried, it improves the app but the windows screen remains too small (icons, writings etc. etc.). the value contained in the "cfg.ini" file changes.
with a 40 ", however, I cannot keep the scale at 100%.
