KC868-AG - Tasmota firmware - cant read ir remote data
Hello folks,
i am facing a problem with my KC868-AG and I would apreciate some help.
first of all i am a noob on tasmota subject so probaly my poor knowledge should be the reason that i dont get result.
as stated in the body of the message, I recently acquired a KC868-AG. As soon as I opened the package, I performed the recording of the tasmota through the link below:
https://tasmota.github.io/install/
[Image: view?usp=sharing]
image 01 - tasmota
after completing the previous step, went to the following path: CONFIGURATION > CONFIGURE OTHER
and insert the following template:
{"NAME":"KC868-AG","GPIO":[0,0,1056,0,480,0,0,0,0,0,1,0,1,1,1,1,0,1,1120,1152,0,7968,0,0,0,0,0,0,1,1,1,1,1,0,0,1],"FLAG":0,"BASE":1,"CMND":"BuzzerPwm 1"}
as in kincony site - template
image 02
after that i have no idea how to read te code of a ir remote control of mine.
when i go to console I can see only this :
image 03 - tasmota console
Is there a way to read the remote control IR signal through the console?
Is there a command model in order to modulate the signal?
Best regards,
hello, i have downloaded this tasmota firmware to KC868-AG. when use Mitsubishi air conditioner remoter, you can see that is feedback IR message.
.zip   tasmota32-ir.zip (Size: 854.45 KB / Downloads: 844)
