KC868-HA RS485 button adapter firmware and PC software v1.0.4.0904 update
improvement:
added "EdgeEvent mode" for KC868-HA.
you can define every button’s “RisingEdge” and “FallingEdge” for “4 different actions”.
RisingEdge: press download button
FallingEdge: release button
4 different actions code:
NoDef: do nothing
EvtON: ON
EvtOFF: OFF
EvtTog: TOGGLE
PC software (HA485_Ctrl_V1.0.4.0904) download:
.zip   HA485_Ctrl_V1.0.4.0904.zip (Size: 911.51 KB / Downloads: 1,216)
firmware BIN file (HA485_KU_V106_221102_SP230903.bin) for KC868-HA download:
.zip   HA485_KU_V106_221102_SP230903.zip (Size: 6.45 KB / Downloads: 1,309)
bootload tool download
[Image: attachment.php?aid=2935]
KC868-HA protocol document download:
https://www.kincony.com/download/KC868-H...d_v106.pdf
KC868-HA online guide:
https://www.kincony.com/how-to-use-rs485...apter.html
Computer is detecting serial port, but in HA485 config tool serial port is not detected.
1: insert usb-rs485 adapter
2: open software
Hi, can you make a video with instructions on how to program the bootloader and use it with esphome.
do you want use KC868-HA board with esphome in home assistant? we will make the video tour soon.
(10-02-2023, 08:16 AM)admin Wrote: 1: insert usb-rs485 adapter
2: open software
I did like in this tutortial. All the time I get an error.
2: open software
SewekO,
This error can be avoided with these mods;
- Start software as administrator
- Plug out all connections, and start again...
Succes :-)
Nic
PS: don't forget to upgrade everithing.
2: open software
SewekO,
Hi, Nick
I start up software with admin privages.
Than disconnect USB to rs485
Wait 5 sec and connect again After that I got again this message
I am using Windows 11 but I do not thing that this is important.
But if a do it with USB to TTL (CH340) or (CP2101) ther is no errors but I can not open bootloader.
can you try with another USB port, or another computer? whether have another problem used COM10?
