AG PRO / KCS Firmware / IR Learning / Node Red
running the AG PRO with the latest firmware.
1. IR Learning - KCS
If I put the firmware to learning via KCS Web frontend, the Samsung TV IR signals are not recorded. Even no beep is played.
If I use Tuya the IR is recorded.
2. IR Learining - Node Red
In addition I found a video on youtube where the Inject node was used to put IR in learning.
Now I checked the HTTP and the MQTT protocoll. There is no explanation on these protocols how to do this.
3. MQTT Problems
I enabled the MQTT to a remote MQTT server.
Using the MQTT-Explorer I can see the Topic with STATE created. So, apparently AG and MQTT server connection is ok.
BUT: STATE is always empty! Also when I send  {"get _datas" : {"value": true}} -  nothing is responded.
