Interfacing multiple LED strips to the AIO board
The AIO board Yaml file for Home Assistant creates "aio-Color-LED-1 to aio-Color-LED-16" outputs, and a single "aio-rgbw" output. How would these 17 different LED devices be connected to a AIO board? On the large AIO connection diagram I downloaded, you show a single LED strip connected to one of the two GPIO ports and a 1-wire humidity sensor connected to the other. Does another interface board need to be purchased and connected to the AIO board to control all these LED devices on the HA dashboard?
here is KC868-AIO yaml: https://www.kincony.com/forum/showthread.php?tid=2736
there are 16 DAC output ,they can use for dimmer output.
there are two LED on PCB can use by user.
free LEDs:
LED-D7(pcb label): PCF8575->U42->P14 (output 37)
LED-D8(pcb label): PCF8575->U42->P15 (output 38)
