A16 - MQTT Issues
Hey,
first of all: Thanks for this great product! I am now trying to connect it via MQTT to Home Assistant. (I had several issues by using ESPHome, so I wanna stick with MQTT for now).
What I did:
  • MQTT Setup within KCS
  • Setup Mosquito and MQTT within Home-Assistant (Already existing)
  • Confirmed that the Packages are received by listening to #
I have used the following YAML within Home Assistants configuration.yaml, customized based on the received packages while listening to #:
mqtt:
   - name: 'kcs868-a16-output-1'
     unique_id: kcs868-a16-output-1
     state_topic: 'KC868_A16/2CBCBB646ACC/STATE'
     command_topic: 'KC868_A16/2CBCBB646ACC/SET'
     state_on: true
     state_off: false
As a result, I can - after restarting Home Assistant control the Output 1.
BUT: It does not show the current status of Output one! (See Screenshot). Status is unknown.
Any Idea what went wrong? What could I check?
[Image: EClPwLZ.png]
take a photo of your KCS mqtt setting webpage.
(12-28-2024, 01:19 AM)admin Wrote: take a photo of your KCS mqtt setting webpage.
Here we go. Not showing the mqtt broker login - which is set and working. As said: Sending requests are working just reading the state seems not to work.
Version 2.2.5 btw - will update to 2.2.10 today.
[Image: iug4yvn.png]
maybe it's your mqtt broker have issue.
