Using SPI connectors labeled for nRF24L01/LoRA on KC868-A6v3
Can the SPI connectors labeled for nRF24L01 and LoRA on the KC868-A6v3 board be safely used to connect other SPI-based modules, such as a CC1101 RF433 transceiver?
Are there any limitations or conflicts with other board functions when using these SPI connectors (e.g. relays)?
you can try to test, these SPI bus just connect with ESP32-S3 pins directly.
