Transmit calculated ADC values via MQTT instead of raw values
Hello everyone,
I have an A6 and an A16.
On the A6, an analog sensor (1-5V) is connected to ADC1. The sensor measures the air pressure. Via gear symbol, I defined a calculation, so I don't see the raw value, but the reading in bar:
[Image: 2025-03-22-07-19-03-Monitor-und-1-weiter...t-Edge.png]
Via MQTT, only the RAW value is transmitted (see left side of the picture). Is it possible to transmit the calculated value (7.29) and unit (bar), so that a possible home assistant auto discovery also shows the correct unit?
maybe in KCS v3 can update it.
Ok, this would a nice feature. it would be worth thinking to move from A6 and A16 to v3
