Connect um330 and kc828 a16
#31
(01-09-2026, 12:52 AM)admin Wrote: if you read by current, can't read by voltage.
If I add a 250Ω resistor across the 4–20mA output (+/−), the voltage across it should become 1–5V (max 5V at 20mA), so it should be measurable by  0–5V analog input. Is this correct and supported?
