07-31-2025, 06:52 AM
friendly_name: b24
board: esp32-s3-devkitc-1
type: arduino
type: W5500
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 39
rx_pin: 38
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_a
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_in_out_1' # for digital input channel 17-24 & ouptut 1-8
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_out_1' # for output channel 9-24
i2c_id: bus_a
address: 0x24
pcf8575: true
pcf8574: pcf8574_hub_in_1
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 4
number: 5
number: 6
number: 7
pcf8574: pcf8574_hub_in_out_1
number: 4
number: 5
number: 6
number: 7
##pull-up resistance on PCB
number: 48
number: 47
number: 40
number: 7
## without resistance on PCB
number: 13
inverted: false
number: 14
inverted: false
number: 21
inverted: false
inverted: false
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
- platform: uart
uart_id: uart_1
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
resolution: 16_BITS
update_interval: 5s
- platform: ads1115
multiplexer: 'A1_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A2_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A3_GND'
gain: 6.144
update_interval: 5s
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "KinCony B24");
B24-HA-without Tuya.txt (Size: 10.92 KB / Downloads: 510)
