07-11-2026, 02:10 AM
friendly_name: MT4
board: esp32-s3-devkitc-1
type: esp-idf
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
web_server:
port: 80
globals:
- id: motor1_direction
type: int
restore_value: true
initial_value: '0'
- id: motor1_speed_value
type: float
restore_value: true
initial_value: '0.5'
- id: motor2_direction
type: int
restore_value: true
initial_value: '0'
- id: motor2_speed_value
type: float
restore_value: true
- id: motor3_direction
type: int
restore_value: true
initial_value: '0'
- id: motor3_speed_value
type: float
restore_value: true
- id: motor4_direction
type: int
restore_value: true
initial_value: '0'
- id: motor4_speed_value
type: float
restore_value: true
output:
# Motor 1
pin: GPIO39
pin: GPIO46
- platform: ledc
pin: GPIO9
frequency: 1000Hz
# Motor 2
pin: GPIO11
pin: GPIO10
- platform: ledc
pin: GPIO12
frequency: 1000Hz
# Motor 3
pin: GPIO13
pin: GPIO47
- platform: ledc
pin: GPIO14
frequency: 1000Hz
# Motor 4
pin: GPIO48
pin: GPIO45
- platform: ledc
pin: GPIO21
frequency: 1000Hz
script:
# Motor 1
- id: motor1_forward
then:
- output.turn_on: motor1_in1
- output.turn_off: motor1_in2
- output.set_level:
level: !lambda "return id(motor1_speed_value);"
- id: motor1_reverse
then:
- output.turn_off: motor1_in1
- output.turn_on: motor1_in2
- output.set_level:
- id: motor1_stop
then:
- output.set_level:
level: 0%
# Motor 2
- id: motor2_forward
then:
- output.turn_on: motor2_in1
- output.turn_off: motor2_in2
- output.set_level:
level: !lambda "return id(motor2_speed_value);"
- id: motor2_reverse
then:
- output.turn_off: motor2_in1
- output.turn_on: motor2_in2
- output.set_level:
- id: motor2_stop
then:
- output.set_level:
level: 0%
# Motor 3
- id: motor3_forward
then:
- output.turn_on: motor3_in1
- output.turn_off: motor3_in2
- output.set_level:
level: !lambda "return id(motor3_speed_value);"
- id: motor3_reverse
then:
- output.turn_off: motor3_in1
- output.turn_on: motor3_in2
- output.set_level:
- id: motor3_stop
then:
- output.set_level:
level: 0%
# Motor 4
- id: motor4_forward
then:
- output.turn_on: motor4_in1
- output.turn_off: motor4_in2
- output.set_level:
level: !lambda "return id(motor4_speed_value);"
- id: motor4_reverse
then:
- output.turn_off: motor4_in1
- output.turn_on: motor4_in2
- output.set_level:
- id: motor4_stop
then:
- output.set_level:
level: 0%
button:
- platform: template
on_press:
- globals.set:
value: '1'
- script.execute: motor1_forward
on_press:
- globals.set:
value: '-1'
- script.execute: motor1_reverse
on_press:
- globals.set:
value: '0'
- script.execute: motor1_stop
on_press:
- globals.set:
value: '1'
- script.execute: motor2_forward
on_press:
- globals.set:
value: '-1'
- script.execute: motor2_reverse
on_press:
- globals.set:
value: '0'
- script.execute: motor2_stop
on_press:
- globals.set:
value: '1'
- script.execute: motor3_forward
on_press:
- globals.set:
value: '-1'
- script.execute: motor3_reverse
on_press:
- globals.set:
value: '0'
- script.execute: motor3_stop
on_press:
- globals.set:
value: '1'
- script.execute: motor4_forward
on_press:
- globals.set:
value: '-1'
- script.execute: motor4_reverse
on_press:
- globals.set:
value: '0'
- script.execute: motor4_stop
number:
min_value: 0
max_value: 100
step: 1
optimistic: true
restore_value: true
initial_value: 50
set_action:
- globals.set:
value: !lambda "return x / 100.0;"
- if:
condition:
lambda: "return id(motor1_direction) == 1;"
then:
- if:
condition:
lambda: "return id(motor1_direction) == -1;"
then:
min_value: 0
max_value: 100
step: 1
optimistic: true
restore_value: true
initial_value: 50
set_action:
- globals.set:
- if:
condition:
lambda: "return id(motor2_direction) == 1;"
then:
- if:
condition:
lambda: "return id(motor2_direction) == -1;"
then:
min_value: 0
max_value: 100
step: 1
optimistic: true
restore_value: true
initial_value: 50
set_action:
- globals.set:
- if:
condition:
lambda: "return id(motor3_direction) == 1;"
then:
- if:
condition:
lambda: "return id(motor3_direction) == -1;"
then:
min_value: 0
max_value: 100
step: 1
optimistic: true
restore_value: true
initial_value: 50
set_action:
- globals.set:
- if:
condition:
lambda: "return id(motor4_direction) == 1;"
then:
- if:
condition:
lambda: "return id(motor4_direction) == -1;"
then:
- script.execute: motor4_reverseyaml file download:
HA_4_motor.txt (Size: 9 KB / Downloads: 163)
