10-29-2026, 08:41 AM
* This program controls a 16-channel relay board via an XL9555
* I/O expander using the PCA95x5 library.
* It sequentially turns ON all 16 relays, then sequentially
* turns them OFF, repeating continuously.
* Pin Definitions:
* - SDA: GPIO 11
* - SCL: GPIO 12
* I2C Address:
* - XL9555: 0x25
* Relay Logic:
* - LOW = ON
* - HIGH = OFF
* Switching Interval:
* - 200 milliseconds
#include <Wire.h>
#include <PCA95x5.h>
#define I2C_SDA_PIN 11
#define I2C_SCL_PIN 12
#define I2C_ADDRESS 0x25
#define DELAY_TIME 200
#define RELAY_COUNT 16
// Use the PCA9555 driver for the XL9555 I/O expander.
PCA9555 relayIO;
// Initialize serial communication.
// Initialize I2C: SDA = GPIO11, SCL = GPIO12, clock = 100 kHz.
Wire.begin(I2C_SDA_PIN, I2C_SCL_PIN, 100000);
Serial.println("XL9555 Relay Control: Starting...");
// Attach the XL9555 to the I2C bus.
relayIO.attach(Wire, I2C_ADDRESS);
// Disable input polarity inversion.
relayIO.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
// Preload all output latches HIGH before enabling outputs.
// HIGH keeps the active-low relays OFF.
relayIO.write(PCA95x5::Level::H_ALL);
// Configure all 16 ports as outputs.
relayIO.direction(PCA95x5::Direction::OUT_ALL);
delay(50);
Serial.println("All relays initialized to OFF.");
// Sequentially turn ON relays 1-16.
for (int i = 0; i < RELAY_COUNT; i++) {
relayIO.write(
(PCA95x5::Port::Port)i,
PCA95x5::Level::L
Serial.print("Relay ");
Serial.print(i + 1);
Serial.println(" ON");
delay(DELAY_TIME);
// Sequentially turn OFF relays 1-16.
relayIO.write(
PCA95x5::Level::H
Serial.println(" OFF");
delay(DELAY_TIME);
1-output-9555.zip (Size: 1,016 bytes / Downloads: 28)
1-output-9555.ino.merged.zip (Size: 194.16 KB / Downloads: 26)
