k868 COL and Domoticz
#11
I have imported nodered to home assisrant and add entitys, change ip. But it doesnt work until I parallel use your PC sowtware and turn on ALWAYS REFRESH. So it nust be always work both (home assistant and pc software) or I made some mistakes in code?
you can set auto report time value and enable "auto report" function in PC software. Then you can close the PC software, only use by home assistant.
THANXX!!!Now its works!
ok, have a good timeSmile
