An experience of installation KC868-A32 in to my own flat.
The KC868-A32 is used as controller of  light and water leak powered by Esphome.[/url]
Water leak detector used this [url=https://aliexpress.ru/item/1005004546201091.html]https://aliexpress.ru/item/1005004546201091.html
 connected through zigbee2mqtt and Home Assistant.
More photo you can find https://drive.google.com/drive/folders/1...sp=sharing
Identified deficiencies of the device:
1. Inconvenient connectors for connecting the load, the wires should go parallel to the board.
2. The connector for the signal wires is not removable and it is not convenient. There is no way to quickly dismantle the device without disconnecting the signal wires.
[Image: DSC-0153.jpg]
1. Do you means pcb's left 5 relay terminal?
2. because if use removable terminal will be larger, the PCB will be longer. if many user like it by removable socket of digital input ports, in furture we can update the hardware version.
