question
Hello
I have a question: After integrating the KC868-E16S module in Home Assistance, do I lose access to the KC868 module web server? I can ping the module to a fixed, programmed IP address. If possible, please provide information on how to work with the RS486 module and the Rf433 interface after integration with HA.
Jack
if you want to use KCS firmware, you can integrate to home assistant by MQTT, not by ESPHome, ESPHome will overwrite KCS firmware.
