I/O naming in Home Assistant
I want to change the names of inputs and outputs on the Home Assistant dashboard from "light x" to a name about what the particular output controls. How do I accomplish this? Do I need to edit the AIO's yaml and reinstall it to the AIO board?
Do I need to edit the AIO's yaml and reinstall it to the AIO board? Yes, just do this. rename in yaml file then re download firmware to your board.
That worked. Thanks!
