A8s v2 inputs
Hello, the inputs on my a8s v2 dont work.
If i short the gnd with any of the input pins nothing happens.
All the relays work fine. Im using I2C address 0x22 for input pcf8574.
Im using the board with esphome.
Code snipet for input
     pcf8574: pcf8754_hub_in
Please advise
Thank you
do you means, all INPUT ports can't use?
you can use this yaml file directly.
  platform: ESP32
remote_receiver:
  pin: 16
  dump:
    - rc_switch
  tolerance: 50%
  filter: 250us
  idle: 2ms
  buffer_size: 2kb
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    address: 0x24
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
    interlock: [relay6]
      number: 4
      mode: OUTPUT
    interlock: [relay5]
      number: 5
      mode: OUTPUT
    interlock: [relay8]
      number: 6
      mode: OUTPUT
    interlock: [relay7]
      number: 7
      mode: OUTPUT
    on_press:
      then:
        - switch.toggle: light1
      pcf8574: pcf8574_hub_in_1
    on_press:
      then:
        - switch.toggle: light2
    on_press:
      then:
        - switch.toggle: light3
    on_press:
      then:
        - switch.toggle: light4
    on_press:
      then:
        - switch.toggle: relay5
      number: 4
    on_press:
      then:
        - switch.toggle: relay6
      number: 5
    on_press:
      then:
        - switch.toggle: relay7
      number: 6
    on_press:
      then:
        - switch.toggle: relay8
      number: 7
  - platform: remote_receiver
    rc_switch_raw:
      code: '001111010111001010111000'
      protocol: 1
    on_press:
      then:
    filters:
      - delayed_off: 200ms
    rc_switch_raw:
      code: '001111010111001010111100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010111001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110010'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110101'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110011'
      protocol: 1
    on_press:
      then:
    filters:
    pin: 14
    device_class: motion
    on_release:
       - script.execute: motion_timer
script:
  - id: motion_timer
    mode: restart
    then:
      - delay: 10s
      - switch.turn_off: light1
      - switch.turn_off: light2
      - switch.turn_off: light3
      - switch.turn_off: light4
Hi, I tested with you code, still nothing.
What can I test?
Here is my code:
  friendly_name : Green House
ota:
web_server:
  port: 80
  auth:
    username: admin
    password: !secret web_server_password
modbus:
  uart_id: mod_bus
modbus_controller:
  - id: a8s
    address: 0x01
    modbus_id: modbus1
    setup_priority: -10
    update_interval: 5s
uart:
  tx_pin: 33
  rx_pin: 32
  baud_rate: 9600
  stop_bits: 1
  parity: NONE
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  - platform: modbus_controller
    modbus_controller_id: a8s
    register_type: holding
    address: 0
    unit_of_measurement: "°C"
    value_type: S_WORD
    accuracy_decimals: 1
    filters:
      - lambda: return x / 10.0;
    address: 1
    unit_of_measurement: "%"
    value_type: S_WORD
    filters:
  - platform: dht
    pin: 14
    temperature:
      name: "Green House Temperature"
    humidity:
      name: "Green House Humidity"
    update_interval: 10s
  #- platform: adc
  #  pin: 36
  #  name: "analog-1"
  #  update_interval: 10s
  #  attenuation: auto
  #  id: "analog1"
  #- platform: adc
  #  pin: 39
  #  name: "analog-2"
  #  attenuation: auto
  #- platform: adc
  #  pin: 34
  #  name: "analog-3"
  #  attenuation: auto
  #- platform: adc
  #  pin: 35
  #  name: "analog-4"
  #  attenuation: auto
  sda: 4
  scl: 5
- id: "pcf8574_hub_out_1" # for output channel 1-8
  address: 0x24
- id: "pcf8574_hub_in_1" # for input channel 9-16
  address: 0x22
    number: 7
    mode: OUTPUT
    number: 6
    mode: OUTPUT
  name: “(6) Z14 Zahon 2”
  interlock: &interlock_group [relay_1, relay_2, relay_3, relay_4, relay_5, relay_6]
  interlock_wait_time: 0.5s
    number: 5
    mode: OUTPUT
  name: “(5) Z13 Zahon 1”
  interlock: *interlock_group
    number: 4
    mode: OUTPUT
  name: “(4) Z12 Green House 2”
    mode: OUTPUT
  name: “(3) Z11 Green House 1”
    mode: OUTPUT
  name: “(2) Z10 od chodnika (T)”
    mode: OUTPUT
  name: “(1) Z9 od plota (T)”
    mode: OUTPUT
    number: 4
    number: 5
    number: 6
    number: 7
    inverted: false
- platform: status
  name: "Green House Status"
  on_state:
    then:
      - if:
          condition:
            binary_sensor.is_on: ha_conected
          then:
            - light.turn_on:
                red: 0
                green: 1
                blue: 0
      - light.turn_on:
            red: 1
            green: 0
            blue: 0
            flash_length: 1s
button:
  - platform: restart
    name: "Restart Green House"
  - platform: safe_mode
    name: "Restart Green House(Safe Mode)"
  - platform: template
    on_press:
    - light.turn_on:
        brightness: 100%
        red: 1
        green: 0
        blue: 0
    on_press:
    - light.turn_on:
        brightness: 100%
        red: 0
        green: 0
        blue: 1
    on_press:
    - light.turn_on:
        brightness: 100%
        red: 0
        green: 1
        blue: 0
    on_press:
    - light.turn_on:
        brightness: 100%
        red: 1
        green: 1
        blue: 1
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2811
    pin: 12
    num_leds: 1
    effects:
           - pulse:
              update_interval: 2s
all INPUT ports can't use? or only some channel can't use.
i suggest you download our KCS firmware to test whether hardware PCB work well.
here is KCS firmware online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
(06-17-2024, 10:23 AM)admin Wrote: all INPUT ports can't use? or only some channel can't use.
Yes all ports dont work as if the pcf doesnt work
you can test with KCS firmware, if can't work , tell me.
Tongue
Tested with KCS firmware and not working:
https://share.icloud.com/photos/0ddXMAIf...a5eeZ0d98A
sorry, i can't download video file from Apple iCloud. when you config by ESPHome. after download firmware, can you check the i2c bus after scanned, which device i2c address have found by ESPHome LOG? maybe it's not 0x22, we can change address for you.
Sorry couldn't test sooner
result of scan:
C][i2c.arduino:071]: I2C Bus:
[C][i2c.arduino:072]:  SDA Pin: GPIO4
[C][i2c.arduino:073]:  SCL Pin: GPIO5
[C][i2c.arduino:074]:  Frequency: 50000 Hz
[C][i2c.arduino:086]:  Recovery: bus successfully recovered
[I][i2c.arduino:096]: Results from i2c bus scan:
[I][i2c.arduino:102]: Found i2c device at address 0x22
[I][i2c.arduino:102]: Found i2c device at address 0x24
[C][pcf8574:021]: PCF8574:
[C][pcf8574:022]:  Address: 0x24
[C][pcf8574:023]:  Is PCF8575: NO
[C][pcf8574:022]:  Address: 0x22
If needed I can upload the video to a different platform just recommend one
add whatsapp number: +86-15381188302 we use ANYDESK remote control your computer to help you.
