Threads: 1
Good afternoon, I would like to ask for your support to be able to load the software to my KC868 I also have the voice module ESP8266 and SINRIC to be able to activate the 32 outputs of the KC868 through the Mobile and through Alexa
I would like to see if you can support me on how to load it with Arduino IDE since with (Voice-Module-Config) I did not have success
https://drive.google.com/file/d/1NR2Ndxx...sp=sharing
I replaced in the code: ************ with my data from my SINRIC account
#define MyApiKey "*****MY ID SINRIC*****" // TODO: Change to your sinric API Key. Your API Key is displayed on sinric.com dashboard
#define MySSID "************" // TODO: Change to your Wifi network SSID
#define MyWifiPassword "***********" // TODO: Change to your Wifi network password
#define Relay1 "**********" // Device ID of Relay1 , which is displayed on sinric.com dashboard
#define Relay2 "***********" // Device ID of Relay2 , which is displayed on sinric.com dashboard
#define Relay3 "***********" // Device ID of Relay3 , which is displayed on sinric.com dashboard
#define Relay4 "***********" // Device ID of Relay4 , which is displayed on sinric.com dashboard
#define Relay5 "***********" // Device ID of Relay5 , which is displayed on sinric.com dashboard
#define Relay6 "***********" // Device ID of Relay6 , which is displayed on sinric.com dashboard
#define Relay7 "***********" // Device ID of Relay7 , which is displayed on sinric.com dashboard
#define Relay8 "***********" // Device ID of Relay8 , which is displayed on sinric.com dashboard
#define Relay9 "***********" // Device ID of Relay9 , which is displayed on sinric.com dashboard
#define Relay10 "***********" // Device ID of Relay10 , which is displayed on sinric.com dashboard
#define Relay11 "***********" // Device ID of Relay11 , which is displayed on sinric.com dashboard
#define Relay12 "***********" // Device ID of Relay12 , which is displayed on sinric.com dashboard
#define Relay13 "***********" // Device ID of Relay13 , which is displayed on sinric.com dashboard
#define Relay14 "***********" // Device ID of Relay14 , which is displayed on sinric.com dashboard
#define Relay15 "***********" // Device ID of Relay15 , which is displayed on sinric.com dashboard
#define Relay16 "***********" // Device ID of Relay16 , which is displayed on sinric.com dashboard
#define Relay17 "***********" // Device ID of Relay17 , which is displayed on sinric.com dashboard
#define Relay18 "***********" // Device ID of Relay18 , which is displayed on sinric.com dashboard
#define Relay19 "***********" // Device ID of Relay19 , which is displayed on sinric.com dashboard
#define Relay20 "***********" // Device ID of Relay20 , which is displayed on sinric.com dashboard
#define Relay21 "***********" // Device ID of Relay21 , which is displayed on sinric.com dashboard
#define Relay22 "***********" // Device ID of Relay22 , which is displayed on sinric.com dashboard
#define Relay23 "***********" // Device ID of Relay23 , which is displayed on sinric.com dashboard
#define Relay24 "***********" // Device ID of Relay24 , which is displayed on sinric.com dashboard
#define Relay25 "***********" // Device ID of Relay25 , which is displayed on sinric.com dashboard
#define Relay26 "***********" // Device ID of Relay26 , which is displayed on sinric.com dashboard
#define Relay27 "***********" // Device ID of Relay27 , which is displayed on sinric.com dashboard
#define Relay28 "***********" // Device ID of Relay28 , which is displayed on sinric.com dashboard
#define Relay29 "***********" // Device ID of Relay29 , which is displayed on sinric.com dashboard
#define Relay30 "***********" // Device ID of Relay30 , which is displayed on sinric.com dashboard
#define Relay31 "***********" // Device ID of Relay31 , which is displayed on sinric.com dashboard
#define Relay32 "***********" // Device ID of Relay32 , which is displayed on sinric.com dashboard
could provide the libraries since some versions vary.
https://drive.google.com/file/d/1vjwkgDT...sp=sharing
This is the type of card I am selecting.
https://drive.google.com/file/d/1K6f3oMS...sp=sharing
I get this error trying to quote it.
Error compilando para la tarjeta NodeMCU 1.0 (ESP-12E Module).
thank you very much in advance for your support
master_Alexa.zip (Size: 5.94 KB / Downloads: 1,082)
Threads: 1,593
because Sinric.com will reach EOL ("End of Life") 2021-Sep-30 after running 3 years for free of charge. here is details:
https://www.sinric.com/login?returnUrl=%2F
now you can use this way without sinric, here is YouTube video tour link:
https://youtu.be/_w_jyZHOEEQ
Threads: 1
(09-14-2021, 12:16 AM) administración Wrote: porque Sinric.com alcanzará el EOL ("Fin de la vida útil") el 30 de septiembre de 2021 después de 3 años de funcionamiento sin cargo. aquí hay detalles: https://www.sinric.com/login?returnUrl=%2F
ahora puede usar de esta manera sin sinric, aquí está el enlace del video tour de YouTube:
ok, pero necesito 27 salidas y aparentemente el video es solo para 10 salidas del dispositivo.
¿Podrías ayudarme con el código de los 27 contactos?
Thank you
Threads: 1,593
in code there is a MAX device define, you can change the number, now default is 10
Threads: 1
09-28-2021, 11:57 AM
(This post was last modified: 09-30-2021, 01:57 PM by elconfa .)
I use this for 32 light:
#ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>
#else
#include <ESP8266WiFi.h>
#endif
#define ESPALEXA_MAXDEVICES 32
#include <Espalexa.h>
#define R2 2
// prototypes
boolean connectWifi();
//callback functions
void F1LightChanged(uint8_t brightness);
void F2LightChanged(uint8_t brightness);
void F3LightChanged(uint8_t brightness);
void F4LightChanged(uint8_t brightness);
void F5LightChanged(uint8_t brightness);
void F6LightChanged(uint8_t brightness);
void F7LightChanged(uint8_t brightness);
void F8LightChanged(uint8_t brightness);
void F9LightChanged(uint8_t brightness);
void F10LightChanged(uint8_t brightness);
void F11LightChanged(uint8_t brightness);
void F12LightChanged(uint8_t brightness);
void F13LightChanged(uint8_t brightness);
void F14LightChanged(uint8_t brightness);
void F15LightChanged(uint8_t brightness);
void F16LightChanged(uint8_t brightness);
void F17LightChanged(uint8_t brightness);
void F18LightChanged(uint8_t brightness);
void F19LightChanged(uint8_t brightness);
void F20LightChanged(uint8_t brightness);
void F21LightChanged(uint8_t brightness);
void F22LightChanged(uint8_t brightness);
void F23LightChanged(uint8_t brightness);
void F24LightChanged(uint8_t brightness);
void F25LightChanged(uint8_t brightness);
void F26LightChanged(uint8_t brightness);
void F27LightChanged(uint8_t brightness);
void F28LightChanged(uint8_t brightness);
void F29LightChanged(uint8_t brightness);
void F30LightChanged(uint8_t brightness);
void F31LightChanged(uint8_t brightness);
void F32LightChanged(uint8_t brightness);
// Change this!!
// WiFi Credentials
const char* ssid = "1111";
const char* password = "2222";
// device names
String Device_1_Name = "luce 1";
String Device_2_Name = "luce 2";
String Device_3_Name = "luce 3";
String Device_4_Name = "luce 4";
String Device_5_Name = "luce 5";
String Device_6_Name = "luce 6";
String Device_7_Name = "luce 7";
String Device_8_Name = "luce 8";
String Device_9_Name = "luce 9";
String Device_10_Name ="luce 10";
String Device_11_Name ="luce 11";
String Device_12_Name ="luce 12";
String Device_13_Name ="luce 13";
String Device_14_Name ="luce 14";
String Device_15_Name ="luce 15";
String Device_16_Name ="luce 16";
String Device_17_Name ="luce 17";
String Device_18_Name ="luce 18";
String Device_19_Name ="luce 19";
String Device_20_Name ="luce 20";
String Device_21_Name ="luce 21";
String Device_22_Name ="luce 22";
String Device_23_Name ="luce 23";
String Device_24_Name ="luce 24";
String Device_25_Name ="luce 25";
String Device_26_Name ="luce 26";
String Device_27_Name ="luce 27";
String Device_28_Name ="luce 28";
String Device_29_Name ="luce 29";
String Device_30_Name ="luce 30";
String Device_31_Name ="luce 31";
String Device_32_Name ="luce 32";
unsigned long Millis = 0;
unsigned long PreviousMillis = 0;
boolean Initialized = false;
boolean wifiConnected = false;
Espalexa espalexa;
void setup()
pinMode(R2, OUTPUT);
pinMode(R2, LOW);
PreviousMillis = millis();
// Initialise wifi connection
wifiConnected = connectWifi();
if (wifiConnected)
// Define your devices here.
espalexa.addDevice(Device_1_Name,F1LightChanged);
espalexa.addDevice(Device_2_Name,F2LightChanged);
espalexa.addDevice(Device_3_Name,F3LightChanged);
espalexa.addDevice(Device_4_Name,F4LightChanged);
espalexa.addDevice(Device_5_Name,F5LightChanged);
espalexa.addDevice(Device_6_Name,F6LightChanged);
espalexa.addDevice(Device_7_Name,F7LightChanged);
espalexa.addDevice(Device_8_Name,F8LightChanged);
espalexa.addDevice(Device_9_Name,F9LightChanged);
espalexa.addDevice(Device_10_Name,F10LightChanged);
espalexa.addDevice(Device_11_Name,F11LightChanged);
espalexa.addDevice(Device_12_Name,F12LightChanged);
espalexa.addDevice(Device_13_Name,F13LightChanged);
espalexa.addDevice(Device_14_Name,F14LightChanged);
espalexa.addDevice(Device_15_Name,F15LightChanged);
espalexa.addDevice(Device_16_Name,F16LightChanged);
espalexa.addDevice(Device_17_Name,F17LightChanged);
espalexa.addDevice(Device_18_Name,F18LightChanged);
espalexa.addDevice(Device_19_Name,F19LightChanged);
espalexa.addDevice(Device_20_Name,F20LightChanged);
espalexa.addDevice(Device_21_Name,F21LightChanged);
espalexa.addDevice(Device_22_Name,F22LightChanged);
espalexa.addDevice(Device_23_Name,F23LightChanged);
espalexa.addDevice(Device_24_Name,F24LightChanged);
espalexa.addDevice(Device_25_Name,F25LightChanged);
espalexa.addDevice(Device_26_Name,F26LightChanged);
espalexa.addDevice(Device_27_Name,F27LightChanged);
espalexa.addDevice(Device_28_Name,F28LightChanged);
espalexa.addDevice(Device_29_Name,F29LightChanged);
espalexa.addDevice(Device_30_Name,F30LightChanged);
espalexa.addDevice(Device_31_Name,F31LightChanged);
espalexa.addDevice(Device_32_Name,F32LightChanged);
espalexa.begin();
else
while (1)
Serial.println("Cannot connect to WiFi. Please check data and reset the ESP.");
delay(5000);
void loop()
espalexa.loop();
delay(1);
//our callback functions
//Control the device
if (brightness)
if (brightness == 255)
Serial.println("RELAY-SET-255,1,1");
digitalWrite(R2, HIGH);
//Serial.print("ON, brightness ");
//Serial.println(brightness);
else
Serial.println("RELAY-SET-255,1,0");
digitalWrite(R2, LOW);
if (brightness)
Serial.println("RELAY-SET-255,2,1");
else
Serial.println("RELAY-SET-255,2,0");
if (brightness)
Serial.println("RELAY-SET-255,3,1");
else
Serial.println("RELAY-SET-255,3,0");
if (brightness)
Serial.println("RELAY-SET-255,4,1");
else
Serial.println("RELAY-SET-255,4,0");
if (brightness)
Serial.println("RELAY-SET-255,5,1");
else
Serial.println("RELAY-SET-255,5,0");
if (brightness)
Serial.println("RELAY-SET-255,6,1");
else
Serial.println("RELAY-SET-255,6,0");
if (brightness)
Serial.println("RELAY-SET-255,7,1");
else
Serial.println("RELAY-SET-255,7,0");
if (brightness)
Serial.println("RELAY-SET-255,8,1");
else
Serial.println("RELAY-SET-255,8,0");
if (brightness)
Serial.println("RELAY-SET-255,9,1");
else
Serial.println("RELAY-SET-255,9,0");
if (brightness)
Serial.println("RELAY-SET-255,10,1");
else
Serial.println("RELAY-SET-255,10,0");
if (brightness)
Serial.println("RELAY-SET-255,11,1");
else
Serial.println("RELAY-SET-255,11,0");
if (brightness)
Serial.println("RELAY-SET-255,12,1");
else
Serial.println("RELAY-SET-255,12,0");
if (brightness)
Serial.println("RELAY-SET-255,13,1");
else
Serial.println("RELAY-SET-255,13,0");
if (brightness)
Serial.println("RELAY-SET-255,14,1");
else
Serial.println("RELAY-SET-255,14,0");
if (brightness)
Serial.println("RELAY-SET-255,15,1");
else
Serial.println("RELAY-SET-255,15,0");
if (brightness)
Serial.println("RELAY-SET-255,16,1");
else
Serial.println("RELAY-SET-255,16,0");
if (brightness)
Serial.println("RELAY-SET-255,17,1");
else
Serial.println("RELAY-SET-255,17,0");
if (brightness)
Serial.println("RELAY-SET-255,18,1");
else
Serial.println("RELAY-SET-255,18,0");
if (brightness)
Serial.println("RELAY-SET-255,19,1");
else
Serial.println("RELAY-SET-255,19,0");
if (brightness)
Serial.println("RELAY-SET-255,20,1");
else
Serial.println("RELAY-SET-255,20,0");
if (brightness)
Serial.println("RELAY-SET-255,21,1");
else
Serial.println("RELAY-SET-255,21,0");
if (brightness)
Serial.println("RELAY-SET-255,22,1");
else
Serial.println("RELAY-SET-255,22,0");
if (brightness)
Serial.println("RELAY-SET-255,23,1");
else
Serial.println("RELAY-SET-255,23,0");
if (brightness)
Serial.println("RELAY-SET-255,24,1");
else
Serial.println("RELAY-SET-255,24,0");
if (brightness)
Serial.println("RELAY-SET-255,25,1");
else
Serial.println("RELAY-SET-255,25,0");
if (brightness)
Serial.println("RELAY-SET-255,26,1");
else
Serial.println("RELAY-SET-255,26,0");
if (brightness)
Serial.println("RELAY-SET-255,27,1");
else
Serial.println("RELAY-SET-255,27,0");
if (brightness)
Serial.println("RELAY-SET-255,28,1");
else
Serial.println("RELAY-SET-255,28,0");
if (brightness)
Serial.println("RELAY-SET-255,29,1");
else
Serial.println("RELAY-SET-255,29,0");
if (brightness)
Serial.println("RELAY-SET-255,30,1");
else
Serial.println("RELAY-SET-255,30,0");
if (brightness)
Serial.println("RELAY-SET-255,31,1");
else
Serial.println("RELAY-SET-255,31,0");
if (brightness)
Serial.println("RELAY-SET-255,32,1");
else
Serial.println("RELAY-SET-255,32,0");
// connect to wifi – returns true if successful or false if not
boolean state = true;
int i = 0;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
Serial.println("Connecting to WiFi");
// Wait for connection
Serial.print("Connecting...");
delay(500);
// Serial.print(".");
if (i > 20) {
state = false; break;
i++;
Serial.println("");
if (state) {
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
pinMode(R2, HIGH);
else {
Serial.println("Connection failed.");
pinMode(R2, LOW);
return state;
Threads: 4
Elconfa can you please use code tags it is hard to read when scroling takes ages
Threads: 1
(09-28-2021, 11:57 AM) elconfa ok muchas gracias lo intentaré. saludos desde Mexico Wrote: Yo uso esto para 32 luces:
#include <WiFi.h>
#else
#endif
#define R2 2
// prototypes
// Change this!!
// WiFi Credentials
// device names
Espalexa espalexa;
void setup()
pinMode(R2, LOW);
if (wifiConnected)
espalexa.begin();
else
while (1)
delay(5000);
void loop()
espalexa.loop();
delay(1);
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
if (brightness)
else
int i = 0;
Serial.println("");
delay(500);
if (i > 20) {
i++;
Serial.println("");
if (state) {
pinMode(R2, HIGH);
else {
pinMode(R2, LOW);
return state;
