KinCony T16M Tiny ESP32 Smart Controller released
KinCony T16M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel MOSFET output, 7 channel 1-wire GPIOs T16M have RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B16M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: T16M-1.jpg]
Model No. KinCony T16M
Description: KinCony 16 Channel Tiny ESP32-S3 Smart Controller – T16M
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C
Installation method: DIN RAIL
Outputs:
16CH MOSFET Outputs, every channel use MAX 10A driver IC
Inputs:
16CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
1-Wire GPIO: 7CH (with pull-up resistance on PCB)
[Image: T16M-6.jpg]
