KC868-A6v3 ESP32-S3 IO pins define
ANALOG_A1  GPIO4
ANALOG_A2  GPIO5
ANALOG_A3  GPIO6
ANALOG_A4  GPIO7
1-wire (pull-up resistance on PCB):
1-wire1:GPIO15
1-wire2:GPIO16
GP8403 DAC i2c address: 0x58
IIC SDA:GPIO12
IIC SCL:GPIO11
Input_IIC_address 0x22
Relay_IIC_address 0x24
RS485 RXD: GPIO18
RS485 TXD: GPIO17
SPI_Bus: (For LoRA/nRF24L01)
CS: GPIO38
MOSI: GPIO43
MISO: GPIO44
SCK: GPIO39
LoRA sx1278:
RST:GPIO42
DIO0:GPIO41
nRF24L01:
CE: GPIO40
RS232:
TXD:GPIO9
RXD:GPIO10
free GPIO on PCB (beside ESP32-S3 module)
GPIO8
GPIO13
GPIO14
GPIO21
GPIO47
GPIO48
I have just purchased this device.
Am I able to turn the free GPIOs on the board (GPIO8, GPIO13, GPIO14, GPIO21, GPIO47, GPIO48) into GPIO switches using the factory KCS v3 firmware?
Ideally I would like to be able to control these pins via MQTT-Home assistant, using the KCS v3 firmware without having to reflash it with ESPHome.
Thanks for your help,
free gpio can define as digital input by KCS v3 firmware.
if you MUST want use free gpio for GPIO switch, you need config by ESPHome.
