KC868_E16S dimentions
I need dimentions for this board, making a front panel. What is the spacing between switches and LED's? Can you publish a PDF-drawing with dimentions for this board?
this is KC868-E16S PCB autocad file "KC868_E16S_V104.DWG", whether help for you?
.zip   KC868_E16S_V104.zip (Size: 271.56 KB / Downloads: 560)
I also need the upper switch/led pcb dimentions.
KC868-E16S only one pcb, maybe you can take a photo of your board.
It is E16P units i have, not E16S.
this is E16P, not E16S.
E16P bottom pcb CAD file:
.zip   KINCONY-E16P-V203.zip (Size: 309.44 KB / Downloads: 536)
E16P top pcb CAD file:
.zip   KINCONY-E16PEXT-V103.zip (Size: 85.14 KB / Downloads: 539)
Could you clarify what the specific dimensions for the spacing between the switches and LEDs are on the E16P board? Also, how can I access the CAD files for both the top and bottom PCBs?
Can you label the size data you want on the photo?
I also need exact measurements for spacing between switches and LEDs, and a detailed PDF drawing for accurate front panel design.
i suggest you chose F16, E16P will stop produce, it have replaced by new version F16. the F16 have shell.
