DM32 ESPHome yaml for home assistant without tuya
  friendly_name: dm32
  board: esp32-s3-devkitc-1
    type: arduino
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
uart:
  - id: uart_1 # RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: dac_uart
    rx_pin: 4
    tx_pin: 6
    baud_rate: 115200
    stop_bits: 1
    data_bits: 8
    parity: NONE
    debug:
modbus:
  uart_id: dac_uart
modbus_controller:
  - address: 1
    update_interval: 5s
  - id: bus_a
    sda: 8
    scl: 18
    frequency: 400kHz
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());
output:
  # CH1 (0x0FA0 / 4000)
  - platform: modbus_controller
    address: 0x0FA0
    value_type: U_WORD
    write_lambda: |-
      // state = 0.0 ~ 1.0 → 0 ~ 4095
      uint16_t reg = (uint16_t) round(x * 4095.0);
      return reg;
  # CH2 (0x0FA1 / 4001)
    address: 0x0FA1
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH3
    address: 0x0FA2
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH4
    address: 0x0FA3
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH5
    address: 0x0FA4
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH6
    address: 0x0FA5
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH7
    address: 0x0FA6
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH8
    address: 0x0FA7
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH9
    address: 0x0FA8
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH10
    address: 0x0FA9
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH11
    address: 0x0FAA
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH12
    address: 0x0FAB
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH13
    address: 0x0FAC
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH14
    address: 0x0FAD
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH15
    address: 0x0FAE
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH16
    address: 0x0FAF
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH17 (0x0FB0 / 4016)
    address: 0x0FB0
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH18
    address: 0x0FB1
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH19
    address: 0x0FB2
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH20
    address: 0x0FB3
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH21
    address: 0x0FB4
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH22
    address: 0x0FB5
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH23
    address: 0x0FB6
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH24
    address: 0x0FB7
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH25
    address: 0x0FB8
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH26
    address: 0x0FB9
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH27
    address: 0x0FBA
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH28
    address: 0x0FBB
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH29
    address: 0x0FBC
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH30
    address: 0x0FBD
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH31
    address: 0x0FBE
    value_type: U_WORD
    write_lambda: |-
      return reg;
  # CH32 (0x0FBF / 4031)
    address: 0x0FBF
    value_type: U_WORD
    write_lambda: |-
      return reg;
light:
  - platform: monochromatic
    output: dac_ch1_out
    default_transition_length: 0s
    output: dac_ch2_out
    output: dac_ch3_out
    output: dac_ch4_out
    output: dac_ch5_out
    output: dac_ch6_out
    output: dac_ch7_out
    output: dac_ch8_out
    output: dac_ch9_out
    output: dac_ch10_out
    output: dac_ch11_out
    output: dac_ch12_out
    output: dac_ch13_out
    output: dac_ch14_out
    output: dac_ch15_out
    output: dac_ch16_out
    output: dac_ch17_out
    output: dac_ch18_out
    output: dac_ch19_out
    output: dac_ch20_out
    output: dac_ch21_out
    output: dac_ch22_out
    output: dac_ch23_out
    output: dac_ch24_out
    output: dac_ch25_out
    output: dac_ch26_out
    output: dac_ch27_out
    output: dac_ch28_out
    output: dac_ch29_out
    output: dac_ch30_out
    output: dac_ch31_out
    output: dac_ch32_out
  - id: pcf8574_hub_1 # for input channel 1-16
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: pcf8574_hub_2 # for input channel 17-32
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_2
      number: 4
      number: 5
      number: 6
      number: 7
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
  ## pull-up resistance on PCB
      number: 47
      number: 48
      number: 7
      number: 40
  ## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted: false
      number: 21
      inverted: false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
esphome yaml file download:
.txt   esphome_dm32.txt (Size: 17.6 KB / Downloads: 282)
