N60 Sensor channel label
#11
(04-19-2026, 04:05 AM)admin Wrote: 1: about "power factor" we will check and later feedback to you.
2: here is new KCS firmware, support rename for every channel and update to home assistant by mqtt auto discovery.
just double click the channel name, you can rename by yourself.
firmware BIN file download:
Thank you!!
1: the "power factor" according to channel1. BL0910 chip only have one channel power factor, can't monitor 10 channels.
(04-20-2026, 12:09 AM)admin Wrote: 1: the "power factor" according to channel1. BL0910 chip only have one channel power factor, can't monitor 10 channels.
Ok, thank you for checking.
Can you tell me if there is a procedure to properly calibrate  the measurements on each of the channels?
use PC software for that:
[Image: attachment.php?aid=9284]
pc software download link: https://www.kincony.com/forum/showthread.php?tid=8406
(04-20-2026, 02:26 AM)admin Wrote: use PC software for that:
Great, Thank you!
here is N60 new firmware, support DST now, you can test it, whether is you wanted.
.zip   KCS_N60_V3.25.0_beta_20260515-142317.zip (Size: 1.04 MB / Downloads: 156)
Thank you for marking changes to allow for the custom Channel name feature.  I do have one more ask however.  Would it be possible to allow longer names (more characters) right now I believe allowed number of characters is 16.  I believe 32 characters should be sufficient.
Thank you in advance.
we will check, maybe in future, next update.
(08-14-2026, 01:50 AM)admin Wrote: we will check, maybe in future, next update.
Thank you!
