Threads: 7
I currently have firmware version 2.2.12 on my KC868_A16 board.
Is there a newer firmware version?
Could you provide a link?
Thank you
Board : K868-A16
Firmware : v2.2.12
Threads: 7
Thank you very much for your feedback.
I have several questions:
1. I see a lot of talk about KCS V3 firmware. What does this firmware offer, and is it compatible with my board?
2. Will the firmware on my board be updated further? I reported several issues, and I don't know if they've been fixed in the latest firmware.
3. I have a new project with several modules for digital input/output, Wi-Fi, and temperature and humidity measurements (Modbus and MQTT protocols).
Should I consider a newer, more powerful board that will be further developed?
If so, could you give me some board recommendations?
Thank you in advance.
Board : K868-A16
Firmware : v2.2.12
Threads: 1,602
1. KCS v3 use for ESP32S3 board, such as KC868-A16v3. You are using KC868-A16, it made by ESP32, NOT ESP32S3, so can't use KCS v3, only use KCS v2. it's old version.
2. KCS v2 will not update for new functions. we update for KCS v3.
3. many kincony board have these resource, but suggest you chose ESP32S3 CPU board, it's more powerful and stable use by KCS v3.
Threads: 7
Thanks for these information.
Regards
Board : K868-A16
Firmware : v2.2.12
Threads: 2
thanks for this information but can you devellop the settings backup and restore for v2?
Threads: 1,602
KCS v2 already discontinue software feature updates, because not enough memory of ESP32.
Threads: 1,602
no, can't , it's different hardware.
