Kincony A4s
"Is there a feature or logic in the Kincony A4S firmware that supports the following switch behavior: a single press toggles the light ON/OFF, while pressing and holding increases the brightness, and releasing then pressing and holding again decreases the brightness?"
no this function. you can config by ESPHome.
KCS v3 have this function, but use by ESP32S3 board.
4 Guest(s)
