N10 with L1 and L2 support ?
I am looking for a meter that supports split-phase or 3-phase; the N30 and others are too big for my project. Any chance the N10 supports split-phase?
 Looking to monitor Grid-tied Inverter generation and grid consumption. I already have a Victron Meter VM-3P75CT and am in need of a second meter with the same capabilities (L1,L2 and L3) and cheaper. This will be integrated to Home-Assistant and Node-Red running on my CerboGX.
 Maybe you can build an N5 with L1,L2 and L3 ? Smile
if want use 3 phase, MUST need at least N30.
(09-16-2026, 11:34 PM)admin Wrote: if want use 3 phase, MUST need at least N30.
For a three-phase configuration without a neutral, can you input L-L (or two hot connections) to the voltage sensor on any of the N-series boards or does it have to measure L-N?
L1-L2 also is ok.
