05-25-2022, 07:00 AM
Hello
1. Is there any setting that I can use KC868-D8 dimmer as "1-10V"?
I have found a led driver din rail format (which would reduce the occupied space in my automation cabinet) but I need to work on 1-10V range instead of 0-10V.
example: https://www.sunricher.com/din-rail-0-1-1...ifications
2. I understand that KC868-D8 is a liniar driver; so in order to achieve a smooth logarithmic turn-on/off of light intensity I should combine it with a logarithmic led driver. please tell if I am wrong.
![[Image: 1627051498-why-you-need-dimming-curves-6...q=60&w=300]](https://www.datocms-assets.com/47741/1627051498-why-you-need-dimming-curves-6.jpeg?ixlib=js-2.3.2&auto=format&q=60&w=300)
source: https://eldoled.com/insights/why-you-nee...ng-curves/
Thank you
Thank you
