water level sensor 4-20ma, 0-100cm, 12v ?
In the circuit diagram post you have a water pressure sensor. I want to do the same.
https://www.kincony.com/forum/showthread.php?tid=3246
Can you recommend one to buy please? It needs to be 0-1m.
Thanks!
you can order this link: https://www.aliexpress.com/item/4001114419508.html chose "2meter" range version.
Sorry, that is 0-5v item?
I thought input A4 needs 0-20mA.
Here is a picture of my current plan.
Thanks.
A8S have 2CH with 0-5v dc analog input ports and 2CH 4-20mA analog input ports.
the water level sensor default is 0-5v output type, if you can 4-20mA sensor, also can make it , just when you order , leave message to aliepxress seller.
