Cable length run?
What is the maximum length of cable run that can be supported for a clamp sensor and still receive accurate readings?
Thanks
how many distance you want to use?
Which current clamps do you advise for this board?
Can you send the link to the store/product?
usually use about 1-2 meter, here is CT clamp sensor have supportted:
https://www.aliexpress.com/item/1005005527700418.html
(10-03-2023, 09:53 AM)deanfourie Wrote: What is the maximum length of cable run that can be supported for a clamp sensor and still receive accurate readings?
Thanks
If you need longer clamp sensor cables, would be best to get them in the mA output version. Idea being that the current output doesn't change over wire length, whereas the voltage does.
yes, "current" type for long distance cable. "voltage" will reduce when cable very long.
