Need Help Getting Started with ESPHome and Home Assistant Integration
Hi everyone Rolleyes
I am diving into home automation for the first time and just got my hands on some Kincony devices. I'm excited to start building my smart home with ESPHome and Home Assistant but could use some guidance.
I've followed the basic setup instructions but I'm hitting a few roadblocks. I'd appreciate any tips on:-
  • Flashing Firmware: What's the best way to install ESPHome firmware on Kincony devices? Are there specific settings I should know about?
  • Configuration Files: Can anyone share example YAML configuration files for common Kincony devices? I need help understanding how to set up sensors, switches, etc.
  • Home Assistant Integration: How do I smoothly integrate my flashed and configured devices into Home Assistant? Any tips for a reliable connection?
  • Troubleshooting: What are common issues to watch out for during setup?
I'm eager to learn and get my smart home up and running.
Thanks in advance for any help!
Respected community member! Heart
1. if you use home assistant, just install ESPHome addon, then download firmware by ESPHome via USB-C cable, it's easy.
2. every KinCony product supply YAML file on forum, you can find in every model zone on forum.
3. just download firmware by ESPHome, it can integrate to home assistant locally.
4. If you encounter any problems after doing it, please ask again.
