09-02-2023, 09:13 AM
ok. I will give it a try later. Thanks
kc868-a32 ethernet problems
11-11-2023, 04:41 AM
Good day everyone, i cannot connect my A32 Board to the Home Assistant. I followed the instruction to copy and paste the yaml file created by the admin esphome_config_A32.txt, but when i click install it has an error and wont continue.
Please guide me how to connect my A32 board to HOME ASSISTANT please. Thanks
11-11-2023, 08:36 AM
change another board name, such as: a32b
try to download again.
05-16-2024, 08:32 PM
(09-01-2023, 10:41 PM)jy1999 Wrote: just got a new kc868-a32, connect to router with ethernet cable, same as my desktop etc. Using power adaptor from the package, 12vdc 2A. But, the connection is not detected by Home Assistance, nor I can see from my router network map etc. Changed ethernet cable as well. Tried resetting the board, and power off/on multiple times, still no lucky. I had exactly the same issue. It's a hardware issue. You need to check if the LAN8720A chip gets hot. If so, you need to replace it yourself or send it back to the seller.
05-16-2024, 10:46 PM
(05-16-2024, 08:32 PM)Aclinic Wrote:(09-01-2023, 10:41 PM)jy1999 Wrote: just got a new kc868-a32, connect to router with ethernet cable, same as my desktop etc. Using power adaptor from the package, 12vdc 2A. But, the connection is not detected by Home Assistance, nor I can see from my router network map etc. Changed ethernet cable as well. Tried resetting the board, and power off/on multiple times, still no lucky. Thanks. I did find the problem of cold solder of the chip. I have tried to fix it yet, but I can see some soldered pins are not very good. |
Users browsing this thread: |
1 Guest(s) |
