NTC 10KOHM temperature sensor
Hello Admin !
Is it possible / how to wire an NTC 10KOHM temperature sensor to the A32 board ? thanks
(i'll join a picture of it)[Image: 51PKKpebNoL._SL1200_.jpg]
it can't directly to connect. you need find a convert module, convert NTC to dc 0-5v output signal, then you can connect with A32 board's analog input ports.
