08-23-2022, 08:59 AM
[Arduino IDE demo source code for KC868-A6]--#12-Web_server_code
KC868-A6_Web_Server.zip (Size: 461.74 KB / Downloads: 413)
* Create Your own WebServer for KC868-A6 Smart Controller*
* https://www.kincony.com **
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0 // reset wifi button
WiFiManager wm;
/* const char* ssid = "xxx"; //your router's ssid
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
//set I2C of A6
PCF8574 pcf8574_I1(&I2Cone,0x22,4,15);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,15);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state",
"relay5state","relay6state"
for(int i=0;i<=5;i++)
pcf8574_R1.begin();
pcf8574_I1.pinMode(i, INPUT);
pcf8574_I1.begin();
WiFi.mode(WIFI_STA);
bool res;
res = wm.autoConnect("KC868-A6-AP"); // anonymous ap
if(!res) {
else {
Serial.println("");
server.begin();
void loop(){
currentTime = millis();
previousTime = currentTime;
header += c;
client.println();
// turns 16 relays on and off
// Display the HTML web page
if (flag_read_di==1)
client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state);
else
// Web Page Heading
client.println("<body><h1>KC868-A6 Web Server</h1>");
client.println();
break;
currentLine = "";
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("");
flag_read_di=0;
ScanKey(); //scan key
void ScanKey()
delay(20);
