Server 16 Raspberry Specs
I have trouble finding the specifications for this unit.
Just basic stuff like:
What is the DC voltage and current requirements?
Voltage rating for digital input
I have the unit in front of me but before I get started I would like to have all the
Thanks!
Power supply: DC12V 2.5A
Digital input: 16CH with optocoupler isolation
cable MAX: 500 meter
dry contact signal
if want connect input voltage:
logic "1": input DC0V
logic "0": input DC12V
free GPIOs from CM4 pins:
GPIO16
GPIO17
GPIO20
GPIO21
GPIO22
GPIO23
GPIO24
GPIO25
here are CM4 hardware resource: https://www.kincony.com/forum/showthread.php?tid=5418
Do you want use install home assistant?
Thanks!
I will try a few different things. Probably start with NodeRed.
Yes, Node red is easy, we have supply sample node, you can download from our forum.
