Configure presence sensor settings in ESPHome
Hello, can I configure settings for your presence sensor in esphome:
https://www.aliexpress.com/item/1005006030673158.html
Or should I configure using remote?
Also, which presence sensor component does it use? LD2410? Thank you.
just dry contact output. so you can use BINARY SENSOR in ESPHome.
(11-28-2024, 08:07 AM)admin Wrote: just dry contact output. so you can use BINARY SENSOR in ESPHome.
Understood. Thank you.
