PROGRAM KC868 A16 DI, DO AND LIQUID CRYSTAL FROM ARDUINO IDE
#11
(01-31-2025, 11:53 PM)admin Wrote: after china new year holidays, will test it then feedback to you.
I think that's great. Happy New Year and I appreciate your kind attention. Best regards.
(01-27-2025, 05:43 PM)Cesarcardca Wrote: I NEED PROGRAM KC868 A16 DI, DO AND LIQUID CRYSTAL I2C FROM ARDUINO IDE. Or if your recommendation is through esphome, I could also try it, I need the syntax, or the devices for inputs and outputs so I can manipulate my program since I also need to interrupt a sensor.
Just add this code to your code for input/output controls.
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
// I2C address of the LCD
#define LCD_ADDR 0x3f
//Some models may use 0x27 address
// Initialize the LCD
LiquidCrystal_I2C lcd(LCD_ADDR, 20, 20);
  Wire.begin(4, 5);  // SDA pin = 4, SCL pin = 5 on the ESP32
  lcd.init();       // Initialize the LCD
  lcd.backlight();  // Turn on the LCD backlight
  lcd.setCursor(0, 0);
  lcd.print("LCD example");
  // Update the LCD content
  lcd.setCursor(0, 1); // Second line
  lcd.print(millis() / 1000); // Display the elapsed time in seconds
  delay(1000);
If you don't know the address of your display's I2C adapter, try finding it with the code below. Most use address 0x3F or 0x27.
#include <Wire.h>
  Wire.begin(4, 5); // Initialize I2C
  while (!Serial); // Wait for the serial monitor to initialize
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices = 0;
  Serial.println("Scanning...");
  for (address = 1; address < 127; address++) {
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0) {
      Serial.print("Device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.print(address, HEX);
      Serial.println(" !");
      nDevices++;
    else if (error == 4) {
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
  else
    Serial.println("Scan complete\n");
  delay(5000); // Wait 5 seconds before scanning again
(01-31-2025, 05:50 PM)Cesarcardca Wrote:
(01-31-2025, 07:42 AM)admin Wrote: because you have not define the i2c bus SDA and SCL pin for ESP32.
these instructions are supposed to be for that. i got it from the Di and DO example on the forum.
PCF8574 pcf8574_1 (0x22, 4, 5) and
PCF8574 pcf8574_2(0x21, 4, 5) is for inputs. right?
is that what you mean?
do you have tested with our demo source code? https://www.kincony.com/forum/showthread.php?tid=1620
I already managed to use inputs and outputs and the 20x4 LCD. thank you so much.
I just need to know how to connect a GPIO input with attachInterrupt.
can you help me please?
KC868-A16 not need to use Interrupt pin for PCF8574, pull is enough for read input state.
(02-09-2025, 02:46 AM)admin Wrote: KC868-A16 not need to use Interrupt pin for PCF8574, pull is enough for read input state.
I know, But I need the program to be interrupted at the point that is right at the moment when the interruption occurs. That means it must be directly from the GPIO.
you need to solder the PCF8574 INT pin to ESP32 one free GPIO.
(02-09-2025, 04:16 AM)admin Wrote: you need to solder the PCF8574 INT pin to ESP32 one free GPIO.
Hello, I have been researching to be able to use a gpio as an interrupt and I see that the 433M_T pin goes directly from the stm32 IO15 to the Header 3 p7, I can use that pin since I do not need the RF circuits and by placing a pull down resistor I can obtain an interrupt in my Arduino code.
it's ok use by 433M send Pin.
