* DS3231 RTC with Arduino
* This program demonstrates how to use the DS3231 RTC (Real-Time Clock) module with the Arduino.
* It includes functionality to:
* - Initialize the DS3231 RTC module
* - Read the current date and time from the RTC
* - Set the RTC time based on a serial command:Command format: DYYYY-MM-DDTHH:MM:SS
* Hardware Connections:
* - SDA: GPIO 8
* - SCL: GPIO 18
#include <DS3231.h>
#include <Wire.h>
String serial_cmd_rcv = ""; // Serial port receiver
typedef struct
byte year; // Last two digits of the year, library adds 2000.
byte month;
byte day;
byte hour;
byte minute;
byte second;
} MY_DATE_STR;
MY_DATE_STR my_date_str = {0};
// Define constants for relay control
#define OPEN_RLY_DATA 26
#define OPEN_RLY_MONTH 4
#define CLOSE_RLY_DATA 2
#define CLOSE_RLY_MONTH 5
// Define pin connections
#define SDA_PIN 8
#define SCL_PIN 18
DS3231 rtc; // Create an instance of the DS3231 RTC
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static bool old_level_high = false;
static bool old_level_low = false;
* @brief Print the current time from the RTC to the Serial Monitor.
static void PrintfCurTime()
Serial.print("Current time is: ");
int year = rtc.getYear() + 2000;
Serial.print(year);
Serial.print("-");
Serial.print(rtc.getMonth(bCentury), DEC);
Serial.print("-");
Serial.print(rtc.getDate(), DEC);
Serial.print(" ");
Serial.print(rtc.getHour(h12Flag, pmFlag), DEC);
Serial.print(":");
Serial.print(rtc.getMinute(), DEC);
Serial.print(":");
Serial.println(rtc.getSecond(), DEC);
* @brief Process serial commands to set the RTC time.
* Command format: DYYYY-MM-DDTHH:MM:SS
static void GetSerialCmd()
if (Serial.available() > 0)
delay(100);
int num_read = Serial.available();
while (num_read--)
serial_cmd_rcv += char(Serial.read());
else return;
serial_cmd_rcv.trim();
if (serial_cmd_rcv == "current time")
PrintfCurTime();
return;
Serial.print("Received length: ");
Serial.println(serial_cmd_rcv.length());
int indexof_d = serial_cmd_rcv.indexOf('D');
int indexof_t = serial_cmd_rcv.indexOf('T');
Serial.print("D index: ");
Serial.print(indexof_d);
Serial.print(" T index: ");
Serial.println(indexof_t);
if (serial_cmd_rcv.length() != 20 ||
serial_cmd_rcv.substring(0, 1) != "D" ||
serial_cmd_rcv.substring(11, 12) != "T")
Serial.println(serial_cmd_rcv);
return;
Serial.println("Setting time...");
my_date_str.year = (byte)serial_cmd_rcv.substring(3, 5).toInt();
my_date_str.month = (byte)serial_cmd_rcv.substring(6, 8).toInt();
my_date_str.day = (byte)serial_cmd_rcv.substring(9, 11).toInt();
my_date_str.hour = (byte)serial_cmd_rcv.substring(12, 14).toInt();
my_date_str.minute = (byte)serial_cmd_rcv.substring(15, 17).toInt();
my_date_str.second = (byte)serial_cmd_rcv.substring(18).toInt();
rtc.setYear(my_date_str.year);
rtc.setMonth(my_date_str.month);
rtc.setDate(my_date_str.day);
rtc.setHour(my_date_str.hour);
rtc.setMinute(my_date_str.minute);
rtc.setSecond(my_date_str.second);
Serial.println("Time set.");
// Initialize the I2C interface
Wire.begin(SDA_PIN, SCL_PIN, 40000);
// Initialize Serial communication
// Set the RTC to 24-hour mode
rtc.setClockMode(false); // 24-hour format
// Print current time to Serial Monitor
PrintfCurTime();
// Clear any remaining serial data
while (Serial.read() >= 0) {}
// Process incoming serial commands
GetSerialCmd();
delay(1000); // Delay for 1 second
7-DS3231-RTC.zip (Size: 1.51 KB / Downloads: 698)
