KC-868-H32B circuit breaker ratings
Dear Admin
I will stat soon to build my DIY of home automation board for my garden as first test for Kincony products before order the rest of hose kincony home.
 automation.
As you discussrd yhe channel load arround 4 A - 220 v each then i will connect 220v load circuits directly to the controller through channel 1 phase CB for each.
Can i use 10A CB for each channel load ?
There are in the market lower to 6A but expensive almost double price of 10A.
Is it ok to protect the controller by 10A CB?
if you use 4A direct to relay, use 10A CB will not good. if >4A already not safety. we suggest you add extend relay or contactor.
