KC868 H32B in node red and home assistant
Hello Engineer
I faced some problem.when I active Alexa bridge and made switch .then connect Alexa node to controller by TCP out
  all okay .... the sound control by Alexa is okay ...the switch appeared in Alexa app in my phone ...but I cant find the switch in Alexa entities in home assistant to control
as attached photos
you can test: place any entity node, whether can find in home assistant.
