improvement:
support integrate to Loxone Miniserver system by UDP command directly. Because when relay state and switch state feedback by HTTP command, Loxone need >= every 10 seconds for update, it's slowly. Now we developing new firmware feedback state by UDP command, it's fast. If you want to add to Loxone Miniserver, just enable option for "LOXONE INTEGRATION", then fill the Miniserver IP and Port.
firmware BIN file download for KC868-H32B Pro controller:
H32B_Pro_V118_230629.zip (Size: 55.51 KB / Downloads: 1,020)
Loxone project file download:
KinCony-32CH-Relay-Controller.zip (Size: 28.23 KB / Downloads: 1,032)
added UDP command protocol:
1. control single relay:
RELAY-SET-255,X,Y
X: relay channel ID
Y: 1: ON 0: OFF
For example a: TURN ON relay1:
Send: RELAY-SET-255,1,1 feedback:RELAY-SET-255,1,1,OK
For example b: TURN OFF relay1:
Send: RELAY-SET-255,1,0 feedback:RELAY-SET-255,1,0,OK
2. when relay state changed by any way , will auto feedback to UDP:
RELAY-SET-255,X,Y,OK
X: relay channel ID
Y: 1: ON 0: OFF
RELAY-SET-255,1,1,OK means: relay1 is ON
RELAY-SET-255,2,0,OK means: relay2 is OFF
3. when digital input port changed, will auto feedback to UDP:
RELAY-GET_INPUT-255,X,Y,OK
X: digital input ID
Y: 1: ON 0: OFF
For example: digital input2 is ON:
RELAY-GET_INPUT-255,2,1,OK
4. when KinCony Smart Controller re power on , will auto feedback (32 channel relay state+ 6 channel digital input state) to UDP:
[2023-06-29 09:20:23.205]# RECV ASCII FROM 192.168.1.200 :4001>
[2023-06-29 09:20:23.206]# RECV ASCII FROM 192.168.1.200 :4001>
[2023-06-29 09:20:23.207]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,3,0,OK
[2023-06-29 09:20:23.208]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,4,0,OK
[2023-06-29 09:20:23.209]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,5,0,OK
RELAY-SET-255,6,0,OK
[2023-06-29 09:20:23.210]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,7,0,OK
RELAY-SET-255,8,0,OK
[2023-06-29 09:20:23.213]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,9,0,OK
[2023-06-29 09:20:23.219]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,10,0,OK
[2023-06-29 09:20:23.222]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,11,0,OK
[2023-06-29 09:20:23.223]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,12,0,OK
[2023-06-29 09:20:23.225]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,13,0,OK
[2023-06-29 09:20:23.227]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,14,0,OK
[2023-06-29 09:20:23.229]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,15,0,OK
[2023-06-29 09:20:23.230]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,16,0,OK
[2023-06-29 09:20:23.232]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,17,0,OK
[2023-06-29 09:20:23.236]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,18,0,OK
[2023-06-29 09:20:23.237]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,19,0,OK
[2023-06-29 09:20:23.239]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,20,0,OK
[2023-06-29 09:20:23.241]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,21,0,OK
[2023-06-29 09:20:23.243]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,22,0,OK
[2023-06-29 09:20:23.245]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,23,0,OK
[2023-06-29 09:20:23.246]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,24,0,OK
[2023-06-29 09:20:23.249]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,25,0,OK
[2023-06-29 09:20:23.250]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,26,0,OK
[2023-06-29 09:20:23.252]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,27,0,OK
[2023-06-29 09:20:23.254]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,28,0,OK
[2023-06-29 09:20:23.256]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,29,0,OK
[2023-06-29 09:20:23.257]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,30,0,OK
[2023-06-29 09:20:23.261]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,31,0,OK
[2023-06-29 09:20:23.262]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-SET-255,32,0,OK
[2023-06-29 09:20:23.265]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,1,0,OK
[2023-06-29 09:20:23.266]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,2,0,OK
[2023-06-29 09:20:23.268]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,3,0,OK
[2023-06-29 09:20:23.270]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,4,0,OK
[2023-06-29 09:20:23.271]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,5,0,OK
[2023-06-29 09:20:23.273]# RECV ASCII FROM 192.168.1.200 :4001>
RELAY-GET_INPUT-255,6,0,OK
RELAY-SET-255,X,Y
X: relay channel ID
Y: 1: ON 0: OFF
X: relay channel ID
Y: 1: ON 0: OFF
X: digital input ID
Y: 1: ON 0: OFF
