KC868-D16 + Relay SSR (Voltage Regulator)
#11
(02-06-2024, 12:37 AM)admin Wrote: if you use "tungsten wire type" light bulb, not MUST >18W. you can add whatsapp number:  +86-15381188302  i can send you a video D16 work with SSR and bulb.
also we are designing new dimmer board, here is video tour: https://youtube.com/shorts/LANReKNJuM8
In fact it is not needed for old style light bulbs. But im talking about led here, its much more common to have for example 2 led light (7w) bulbs connected in series that generate 14w load.
What im thinking is to put some kind of resistor in the ssr output (kind of bleeder resistor), so I ensure to always have > 18w of load, my doubt is how to the math to buy the resistor...
There are several on Aliexpress, can you help me to choose ?
https://pt.aliexpress.com/item/100500299...00730166_1
You can test without resistance first, which requires practice to verify. In theory, it is useless.
