E16T IFTTT Limit and Logs
I'm currently running E16T using E16S KCS Firmware and linked to Tuya APP
1. Is there a limit to how many IFTTT automations can be run on E16T using KCS firmware without running into memory issues and causing instability?
2. Can IFTTT and Tuya automations be run at the same time? If so which will override the other if there are clashes.
3. ⁠Is it possible to check the memory utilisation using the KCS firmware?
4. ⁠Can the device post logs to external databases using IFTTT?
it's not easy to say how many command limit for IFTTT. i think you can connect your USB cable to PC, use serial debug tool to monitor logs. Because when board running with KCS firmware, USB cable will print logs always.
